Hello
How extend the memory of the base ?
Regards
Xavier Laurent
Hello
Regards
Xavier Laurent
This depends on your base model. The H2L supports storage expansion with a microSD card, while the H2E supports storage expansion with a hard drive.
Hello,
It’s a H1L model
Regards
Xavier L.
Sorry, the aosu Base H1L doesn’t support storage expansion.
If your camera supports an SD card, you can install one directly in the camera to expand the storage for that individual device.
The H2L and H2E HomeBases are the models that include a storage expansion slot.
