farm security
Looking at installing your security system at farm location. Internet at the house but shop and shed are 500 feet away. Planning on using a p2p wireless link to connect at the remote location. Attaching a diagram of what I think could work. Will you advise whether this p2p proposal will work? I have a similar setup at another farm location and has been working fine. Trying your newest system to see if that might solve my problem here.
I have one of your 4 cam / doorbell at my house and it works well. I did have to use a couple of external solar panels on 2 locations that don’t get the full sun all day. They do stay up for weeks but I didn’t want to pull them down to charge. The external panels do keep them continuously charged and has worked well.
This will be the fourth system of yours I have installed. Easy to set up and maintain. Thanks.
Marion Combs
Hi,
We’re truly sorry to hear that you’re experiencing this issue!
To get this resolved for you as quickly as possible, please reach out to our dedicated support team directly through the app. Our live agents will be able to assist you one-on-one and investigate the details.
How to reach us:
Open the aosu App ➔ Tap Support (bottom right) ➔ Select Online Support to start a chat.
Thank you for your patience and support!
I am not having an issue. I want to know if the cameras at the end of the p2p wireless link will work. The routers will be on the same network so I think they should connect and be accessible via the aosu app. I just want to confirm before I proceed. I think I included everything I am using in the attached sketch. Can someone confirm this will work?
Hi,
How to reach us:
