Is anyone else experiencing not being able to view events on your cameras anymore without upgrading to a subscription? I used to be able to just view my recent events but now, after over a year, it’s making me buy a subscription if I want to view them…
You should have an SD card in your hub. If you cancel your subscription, all videos are recorded to that card. If you haven’t bought and installed one, the system simply has nowhere to save the video files. If you run into any issues, check your SD card first to make sure it’s not full.
No such thing on my hub
Can’t find its location. My two indoor monitors still have the capacity to review/ open the calendar of recorded events but not my outside cameras u
Hi,
We’re truly sorry to hear that you’re experiencing this issue!
To get this resolved for you as quickly as possible, please reach out to our dedicated support team directly through the app. Our live agents will be able to assist you one-on-one and investigate the details.
How to reach us:
Open the aosu App ➔ Tap Support (bottom right) ➔ Select Online Support to start a chat.
Thank you for your patience and support!
