Landscape view
Is anyone all of a sudden having issues turning the video landscape. When I turn the phone picture goes half screen and freezes up. The program eventually crashes. I rebooted my phone and installed a pending Apple update to see if it cured the issue and it is still the same. Any help would be great.
Yes I had the same problem on my iphone but I changed my display zoom size down and it fixed the problem. I also did a restart on it so that may have helped also.
Mine is doing the same thing. The company isn’t being helpful at all
Same issue with multi-culturel view. Any help ?
Sorry you’re running into this issue — that definitely sounds frustrating.
From what you described, it looks like the issue may be related to certain iOS display scaling settings (larger display/text settings instead of the default setting).
I hope this post could help you with such issue
