Thank you for contacting Aosu Technical Support! For us to better assist you, kindly answer the following questions
1.) Does the solar panel have direct heat from the sun?
2.) Is there something blocking the solar panel from receiving heat from the sun?
3.) Have you already tried charging the camera using a different charging cable?
