Hey, from what I can find, the Video Doorbell Pro appears to come with an aosuBase Mini, as AOSU’s product listing says “aosuBase Mini Inclusion.” However, I’m not 100% certain which package/version you would receive, so I’d recommend confirming that with AOSU before purchasing.
Also, the Doorbell Pro’s aosuBase Mini is a separate base from the one used by your D1 Max cameras, so I wouldn’t assume the doorbell can be added directly to your existing D1 Max base. AOSU specifically notes that the Doorbell aosuBase Mini isn’t compatible with those camera systems.
