Adding cameras
I just purchased and installed the T2 Ultra 4K security cameras(4 with base). I now want to buy 6 additional cameras for inside. Will the IndoorCam P1(3-Pack) have any syncing issues if additional them?
Thank you
Thank you for reaching out, and congratulations on your new T2 Ultra 4K system!
At the moment, aosuBase does not support adding IndoorCam P1 cameras, so the IndoorCam P1 3-Pack would not be able to sync with your current T2 Ultra base system.
That said, we are actively working on improving compatibility between aosuBase and aosuCortex to support a more flexible multi-device setup in the future.
Best regards
