Aosu cortex vs standard home base
Hello, I recently purchased the T2 Ultra 4k system, this is the 4 camera bundle through Amazon. This kit comes with the all white base system but it seems that on the website, you sell this exact same kit with with the Aosu cortex base (white/black) home base. Why is tjerr abig difference between your product on amazon and in your website?
Is there a way for me to acquire the new base?
Thank you for reaching out.
Yes, you are right, our official website currently has two T2 Ultra 4K bundle options available: one comes with aosuBase, and the other comes with aosuCortex.
At the moment, aosuBase and aosuCortex are not sold separately.
Here are the main differences for your reference:
aosuBase H2L
  • Built-in 32GB storage
  • Supports SD card expansion up to 1TB
  • Supports up to 6 connected devices
aosuCortex
  • Supports hard drive expansion up to 16TB
  • Supports up to 8 connected devices
  • Includes local AI recognition for different people, vehicles, and pets
I hope this helps you better understand the differences between the two systems and decide which one best fits your needs.
If I purchased the T2 pro dual lenses camera, would I be able to add it to my T2 Ultra 4 camera bundle? Will it be compatible with my home base?
If your aosuBase model is H2L, then both T2 Ultra and T2 Pro can be connected to it.
