Aosu V8S13 ( Ultra) : Hardwired but battery is still draining
Hello
Installed it with 98% battery fully charged yesterday with hardwired it.
On the app it shows charging but battery is draining. It’s around 70% in 24 hr.
I am using plug in adapter with out put range of 12v to 24 V 500 amp.
Any idea what’s wrong here ? Does it need 30V with more amps? Anyone faced same situation ?
Hi,
We’re truly sorry to hear that you’re experiencing this issue!
To get this resolved for you as quickly as possible, please reach out to our dedicated support team directly through the app. Our live agents will be able to assist you one-on-one and investigate the details.
How to reach us:
Open the aosu App ➔ Tap Support (bottom right) ➔ Select Online Support to start a chat.
Thank you for your patience and support!
