Hey everyone,
I have researched about the best solar powered outdoor lights in 2025 because I’m upgrading my backyard and walkway lighting. I’ve read tons of reviews from sources like The New York Times’ Wirecutter, Consumer Reports, and Popular Mechanics, and they’re all highlighting these two as top picks:
2500LM Solar Lights Outdoor with Motion Sensor
https://www.amazon.com/daphino-Waterproof-Security-Non-Remote-2-Pcs/dp/B0D47FT8LN/?th=1
SOLPEX Solar Deck Lights Outdoor 16 Pack
https://www.amazon.com/Solpex-Lights-Outdoor-Waterproof-Pathway/dp/B07YC8PVF1/?th=1
The issue is, I’m having a tough time deciding which one fits my needs better. I want something reliable that works well even in low-sun conditions, and ideally can be used around the driveway, fence, and backyard. I’m also looking for decent battery life, weather resistance, and maybe some smart features if possible.
Have any of you tried these or have better suggestions for 2025?
Any recommendation would be super helpful!
Thanks in advance!
