Deleting old events
How do I delete all old events ? I dont need to save any and it says its full.
Julia
Hi. It may help to note what device you have. But I long pressed on a video and the option to delete popped up. This is for the 2k solar security camera.
From the Events screen, hit the three lines on the upper right hand corner.
Then hit “Select”.
This will give you the option to delete multiple videos at once. You can either pick the ones you want individually, or tap “Select All” to delete 100 at once (you can do this multiple times - you’re just limited to 100 clips at one time). You can select or deselect videos by clicking the circle on the left hand side of each individual video.
To delete the selected videos, hit the trash can icon on the bottom right hand corner.
(The black boxes you see in these images were added by me after the fact to censor passersby and my location. They aren’t what you’ll see on these screens.)
I only have “FILTER” when I select hamburger
The app is crap.
Although I am sure the features are available if you pay for cloud.
