Seems like overtime I as a question they redirect and avoid answering them at all cost.
How many bases stations can I have on 1 network?
How many cameras can I have on 1 base?
The problem is, these are apparently made for small houses with the base centrally located inside the house.
I’m working on multiple barns.
If I put the base in one corner of the barn, the camera on the opposite corner has a bad signal and doesn’t record shit. The Camera on the opposite corner or another barn that is apparently too many feet away has NO signal. Putting a wifi range extender in that other barn is no help. A 2nd base connected to that range extender would work BUT you can’t get these idiots to answer a simple question.
Can I just put SD cards in these cameras, connect them to my wifi and toss the useless base in the trash?
