Doorbell ring function
When press the ring button on the doorbell, the video doorbell outside of the house will ring, the inside HomeCortex will ring and your phone will ring.
Your phone will receive a notification and a video call, you can click hang up or to answer it.
For the chime and volume, You can set it in the app, Settings-Chime Settings
Our device only has 3 ringtones by default, you can select different ringtones for the doorbell and HomeCortex separately. You can also set doorbells and HomeCortex to the different volume level.
