How to set motion detection technology?
Edit Motion Detection Area:
You can add / delete Motion Detection Area in "Settings - Motion Detection - Detection Zone ", up to three detection areas can be added.
Set Sensitivity of Motion Detection:
You can slide left or right in “Settings - Motion Detection - Detection Sensitivity", and adjust sensitivity gear.
Is this for all of Aosu cameras? I have 4 C9C units and I don’t see anything under Motion Settings about Detection Zones. All I see is whether AI Person only or All Motion and Sensitivity. I really could use Morion Zoning because I have a tree shadow that sets the off in the afternoon.
IDK what the C9C units are. But go to the camera, motion detection, if you want person only then select it, select detection zone, then build your zones up to 3, detection sensitivity is all the way at the bottom.
Thanks for the response. The C9C units are the are the Solar Micro SD card wifi units (No hub). Here is a pic of what my motion detection screen looks like.
I don’t think your screen shot is complete. Looks like the bottom of the sensitivity area is missing. Have you tried clicking on that area. On mine it takes me to another screen to customize the areas.
Mine also has a slider at the bottom for adjusting sensitivity
Hi I’ve setup the intruson zone no problem but there is no detection zone in the app? I have detection settings that allow me to turn motion on and off, setup intelligent detection (AosuProtect+ required), track motion and set sensitivity but no detection zone. How do I set the camera to only track with a given area? We are on a busy street and it picks up people walking past on the street but not on our property. I want the camera only to track people who enter the same area as the intrusion zone I’ve setup i.e. our driveway. Many thanks
Did you ever get an answer for this issue? I have the same cameras and same issue. No way to set a specific detection zone. I have read through all instructions and replays with no results to my issue.
I’ve attached the rest of the Motion Settings screen. Yes, there a slider but tapping on the Detection Sensitivity area does nothing.
Nothing as of yet. I’m the afternoon I have to snooze mine because it constantly goes off due to a shadow from a tree.
Since AI was added person detection no longer works. You will get no events when set to person and without person if a leaf blows by the camera it goes off. Have told online support this multiple times since early August update. September 5th update still has not fixed it. My outside cameras are completely useless now. Remove the AI garbage and give up back working notifications. Current App version is 4.4.0 on Android.
Hello
I have a c9s2
Took me a while to find this.
I have to go to settings, ai surveillance, intrusions settings, then detective zone .
There you can and zones .
Thanks for the reply! I have Model C9C units and they don’t have the settings you are talking about.
Hello
The only difference between the c9c and c9s is the c9s has a floodlight.
I am using aosu app Version 4.4.46 from Google play.
On settings you should have ai surveillance, click on that. Then.
Intrusions settings
Detective zone
There you can add a zone or region.
Hope this helps
Can you send a screenshot after pressing on settings ?
I don’t have Intrusion Setting once I click on AI Surveillance.
I’m running the same app version as you.
Hi
Looks like different countries have different settings.
I am based in the United kingdom and pay the basic monthly fee.
Mine is totally different to yours.
Sorry can’t help
I’m new to these camera’s. I’ve got the C9C3CA11 Model. I dont see anything you are talking about. I keep getting leaves setting mine off as well now. I live in the country with a lot of leaves blowing around too. Any help would be appreciated. Thanks
I love motion detection. It helps me to follow where my cat is off wandering. :folded_hands:
