Hi. I bought the home base + two 2k camera package last year. Can I add a third 2k camera to this home base?
Hi! Yes .You can add a third 2K camera to your existing aosu HomeBase, as long as the HomeBase model supports additional cameras and hasn’t reached its pairing limit.
Here’s what you need to check:
1. HomeBase Model Compatibility
- Most aosu HomeBases (especially the one that comes with the 2K camera kit) support up to 4 cameras.
- You can check this in the Aosu app → Tap the HomeBase → See how many devices are currently paired and if there’s an “Add device” option available.
2. Same Series Camera
Make sure the third camera is from the same series (e.g., aosu 2K security cam) and specifically compatible with your HomeBase.
