Can you connect the C2E indoor camera to the aosu Cortex Base to utilize the onboard memory, or will the camera only record to an SD card installed in the camera?
Hi.Currently, C2E indoor cameras do not support connection to a aosu Cortex. Local storage and cloud subscriptions are supported; for local storage, simply insert an SD card. ![]()
Welcome to the Aosu community @johnfichtner
