Camera moving to far right on own
Have 2 D1 classic cameras one has started to move to the extreme right on its own. Done a re start and calibrate. Still moves after being repositioned after a few seconds. Any help.
Hi, it sounds like you already did the recalibrate, so I’m wondering if your default view might have changed or needs set. In your settings, click “Default View” and “Reset”. After making the adjustment, see if now returns to that spot instead of too far right. I hope this works for you :folded_hands:
I am having the same issues that you responded to. I tried the reset and it still doesn’t allow me to move the view. Any other suggestions?
