First check if the doorbell is out of power
try to remove the doorbell and reconnect again. Remember and send us what the HomeCortex says if you fail to connect the doorbell, and the color light showing on the HomeCortex to us on aosu app online service, so we could find you a better solution according to your specific issue. Meanwhile, please check does the HomeCortex is too far away with Doorbell.
