Moisture or fogs inside the camera
There are a few things that you may consider on how to get rid of the moistfog inside your camera:
  1. Kindly bring the camera back inside (remove it from the original installation point)
  2. Try wiping the outer lens cover (not the lenses) with a micro-fiber cloth
  3. Try using a hair dryer to heat slightly (not too much heat)or let it dry for 2-3 days (If the issues occur frequently)
  4. Try applying an Anti-fog Spray on the Security Camera’s outer lens cover
  5. Try putting the camera into a waterproof box, drill a hole in the box, and cover the hole with water-resistant materials until the moisturefog is gone.Let online support on aosu app know if you need further assistance.
