My camera is making a weird nosie
Please try the following steps to troubleshoot:
1.Try shaking the camera and listen carefully for any abnormal sounds caused by loose parts;
2.Please turn the camera manually to see if there is any resistance. Then click the PTZ in the app and observe whether the camera will move according to the instructions;
3. Make sure the rubber plug on the camera is securely covered, otherwise it will affect the rotation of the camera.
