Can't Rotate, PTZ problem, Abnormal Rotating
  1. Please turn off the auto cruise and track motion in the setting.
  2. The camera will auto-rotate once every day at the ramdom time at night for auto-correction. If you have turned the above options off but the cameras still randomly move more than once each day, please check if the exposed cable for the camera is long enough (at least 15CM) and also check if there is a wall block the camera rotates normally.
