Notification settings
You can go to the app, Settings-Notification settings to adjust this function.
If you think notification is too annoying, you can turn it off completely in notification settings.
There are two types of notification modes, the immediate mode, when motion is detected, the app will push a notification ASAP.
As for the Intelligent mode, when you click it, you will see event types like Ring, which means someone rings the bell, like passing, staying, and Anti-Theft warning. You can select the types of notifications you want to receive and those you don’t want to receive. When you set it on, the app will push notifications by intelligent algorithm.
And the final one, Snooze function inside the notification, when you click it, you will see an
Interface where you can set up a time range when you will not receive any notifications,
This function means the device will keep working but will not send you notification in the time range you set when you think it is too annoying.
Did you remove the “ring” setting under “intelligent notifications”? I only want to receive notifications when the doorbell rings, not every time motion is detected.
The “ring” and “passing” settings are missing in the app I only want a notification when someone rings the doorbell. I want the doorbell to record all motion, but I don’t want a notification every time that happens. How do I set that up?
Any help on this?
Hi, you can turn on the button to receive the notifications about person when detected,
