Outdoor Surveillance Camera with Solar Panel- Rotation speed
Hi all, has anyone experienced delayed rotation in the external cameras? Could this behaviour be related to network bandwidth or latency? Many thanks in advance
Delayed rotation or slower pan/tilt response on outdoor cameras can sometimes be related to network conditions, especially latency or connection stability rather than just raw bandwidth speed.
A few things that may affect camera rotation responsiveness:
• Weak or unstable Wi-Fi signal to the camera
• Network latency or packet delay
• Heavy network traffic/congestion
• Distance between the camera and router
• Temporary app or firmware issues
You could try checking:
• Wi-Fi signal strength in the camera settings
• Whether the delay happens on both Wi-Fi and mobile data
• If the camera responds faster when you are closer to the router
• Whether firmware updates are available
• Restarting the camera and router
It would also help to know:
• Which camera model you’re using
• Whether the delay happens all the time or only occasionally
• Approximately how long the delay is (1–2 seconds vs much longer)
That can help narrow down whether this is expected network latency or something abnormal.
