Models starting with H1L are the earliest generation of aosubase modules. Older versions lack an SD card slot and cannot expand memory capacity.
Models starting with H2L are the second generation of aosubase modules. You can find the SD card slot on the back to insert an SD card. Currently, the largest supported SD card capacity is 1TB.
Models starting with H2E are our lastest aosuCortex modules. They support SSDs and can be expanded up to 32TB.
On peut insérer une carte SD de 128go dans le port prévu à cet effet, sauf quand il y a une base, dans ce cas, on l’insère dans la base (qui est livrée avec une SD de 32Go).
2.
3.
Models starting with H2E are aosuCortex modules. They support SSDs and can be expanded up to 32TB.
Older versions Models starting with H1L lack an SD card slot and cannot expand memory capacity.
Second generation of aosubase modules which are models starting with H2L have the largest supported SD card capacity up to 1TB. Models starting with H2E are aosuCortex modules. They support SSDs and can be expanded up to 32TB.
Aosu have three modules each with its particular capacity:
Models starting with H1L are the earliest generation of aosubase modules. Older versions lack an SD card slot and don’t have expandable memory capacity.
Models starting with H1L are the earliest generation of aosubase modules and are older versions. They lack an SD card slot and as such their memory capacity can not be expanded. The 2nd generation module that start with H2L can be expanded up to 1TB with SD card. AosuCortex modules support SSDs and can be expanded up to 32TB.
Models starting with H1L are the earliest generation of aosubase modules. Older versions lack an SD card slot and cannot expand memory capacity. Models starting with H2L are the second generation of aosubase modules. You can find the SD card slot on the back to insert an SD card. Currently, the largest supported SD card capacity is 1TB. Models starting with H2E which are aosuCortex modules support SSDs and can be expanded up to 32TB.
Currently, Aosu offer three (3) model types. Each with it storage capacity.
You can distinguish them by their serial numbers located at the bottom.
Models starting with H1L are the earliest generation of aosubase modules. They lack an SD card slot and cannot expand memory capacity. It comes with 32GB built-in local storage.
Models starting with H2E are the lastest aosuCortex modules. They support SSDs and can be expanded up to 32TB.
AOSU currently offer three types of aosubase modules. You can distinguish them by checking the serial numbers on the bottom:
1. Models starting with H1L are the earliest generation of aosubase modules. Older versions lack an SD card slot and cannot expand memory capacity.
2. Models starting with H2L are the second generation of aosubase modules. You can find the SD card slot on the back to insert an SD card. Currently, the largest supported SD card capacity is 1TB.
3. Models starting with H2E are our lasted aosuCortex modules. They support SSDs and can be expanded up to 32TB.
Aosu currently offer three types of aosubase modules. You can distinguish them by checking the serial numbers on the bottom :
3. Models starting with H2E are lasted aosuCortex modules. They support SSDs and can be expanded up to 32TB.
Models starting with H1L (Older versions ) lack an SD card slot and cannot expand memory capacity.
Second generation of aosubase modules which are models starting with H2L have the largest supported SD card capacity up to 1TB. Models starting with H2E are aosuCortex modules which support SSDs and can be expanded up to 32TB.
Currently three types of aosubase modules are offered by AOSU. You can distinguish them by checking the serial numbers on the bottom:
