installed first home base with 4 cameras. Everything set up and connected perfectly. Now I am adding a second home base with 3 cameras. The home base will not connect. It has a flashing green light on base, which means it is ready to connect, but it will not connect. Has anyone had this problem? Need help!
I have same problem with second H1L base on pro system. I have tried two new H1L’s with same symptoms. My router is a dual band tp-link AX1800 Wi-Fi 6. Called AOSU support and got youtube trouble shooting tips. Last will be a call to TP-Link to see if they have an idea.
Could you please provide the aosu account that your device is bound to? I can help check the binding status for you.
The account is ida@mangee.net. On my wifes phone.
