Does the camera support third-party device control?
After binding your App account with your Amazon / Google account, you can control the device through the Amazon Echo / Google Home smart assistant.
New here hi! Any help would be greatly appreciated, thank you in advance. Would I be able to use my CS9 cameras with home assistant? I would like to build a dashboard and use them in future automation projects. I would like to continue to use Aosu CS9 cameras or other Aosu devices so I can use them wirelessly. Again thank you.
Kindly follow the steps below on how to connect the camera to Google Home
Step 1 Download and setup the cameras to the Aosu app
Step 2 Download and setup the Google Home and Assistant apps
Step 3 Open the Aosu app, go to the camera’s Settings, tap ““OK Google””, then follow the on-screen instructions.NOTE The camera cannot display on the Google Home App, but it will only show the live stream on the Google Nest Hub device.
Hey Captain,
account is linked to google, devices are bound. Is it possible to perform actions with cameras? I want to switch them on and off programatically.
Thanks for your help!
Best, Stefan
Yes, our community also has relevant instructions. If you want to know more, you can search for relevant “third party” articles in the aosu community.
I’m also looking for some guidance (as the other member on this thread) on home assistant integration as well. Basically how to get/configure the camera’s RTSP url? I have the 5MP Ultra HD Doorbell camera wireless, and the solar outdoor camera (C7L2BA11).
Thanks!
