How to install a solar panel?
The solar panel must be placed where there is continuous sunlight all the year round. A direct sunlight for several hours a day can suffice for the camera’s power needs
Note: The solar panel may be susceptible to weather conditions, seasonable change, geographic location and other factors.
  1. The provided screws are used to secure the mounting base to the desired position. If the surface of the mounting location is soft, a hole may be drilled on the wall by a φ6.0 bit and with an anchor bolt being inserted, and then the mounting base is secured by screws.
  2. First of all, install a screw cap to the universal joint, and then screw the round head nut into the universal joint.
  3. Screw the universal joint into the back of the solar panel, and secure it with provided nuts.
  4. Screw the tightened screw cap into the mounting base. Make sure that the universal joint faces upward.
  5. Adjust the solar panel toward left or right, loosen the screw cap, rotate the screw rod, and then tighten the screw cap after the solar panel is properly installed.
  6. The angle of the solar panel may be adjusted upward or downward, even up to 90°.
Note: After installation, please check whether all connections are tight. Keep the solar panel in a mounting angle of 30-45° from the horizontal plane
Connect the solar panel to the camera, as shown in the picture below (open the silica gel cover at the bottom of the camera, plug the power wire in the USB-C charge port, and then close the cover and loosen the power wire on the solar panel).
Are Aosu solar panels available for separate purchase. When I purchased my kit, I did not think I would want panels. Now I have a couple of locations that get more activity and would benefit from solar charging.
I did not see these available separately on your site.
