Winners Round 12 Announced!
Missed it? Catch up here: 📢【Round 12 | aosu Security Quiz】—Double prizes Round!Late-Night Stranger Detected? - #11 by aosu_Captain
Round 13 , better understand your solar camera charging!
Let’s go through a quick check together to better understand why your solar camera might not be charging.
Imagine this scenario:
“Your camera is installed under the roof eaves, facing your backyard. The solar panel is placed on the wall just above the camera. There are some tree branches nearby, and during parts of the day, the area is shaded. You’ve noticed that even on sunny days, the battery percentage doesn’t go up.”
Based on this situation:What do you think might causing the issue?
This Round’s Question
Q: How to do when solar camera is not charging?
Hint
You can find the answer in the aosu Community.
Just search this title in the top right corner:
“How to do when solar camera is not charging?”
Weekly Prizes
How to Participate
Go to the aosu Community and search for the article title using the search bar in the top right corner.
Read the article and leave your answer in the comments section of this post.
All correct answers will be entered into this week’s prize draw!
Quiz Period : August 6th - August 12th
Winner Announcement : Winners will be posted in the comments section of this post next Wednesday — stay tuned!
Think you know the answer?
Join the quiz and comment below for a chance to win exciting prizes!
Sounds like the Aosu solar panel attached to the Camera isn’t getting enough direct sunlight. If it’s shaded by the eaves or nearby branches for most of the day, it won’t charge the battery properly—even if it seems sunny out. Solar cameras really need full, unobstructed sun to work well. I’d try repositioning the Solar panel where it gets direct and maximum solid sunlight for several hours daily.
I believe the tree branches and angle of the solar panel are creating the issue of not charging fully even on sunny days. Based on the time of the year, angle of the sun and the amount of tree coverage. My solution would be to reposition the solar panel and perhaps trim the trees as an added bonus.
Make sure that the solar panel is positioned to receive direct sunlight and is not obstructed by eaves, tree leaves, or other shadows. Try to reduce Camera Activations: Frequent motion triggers can cause the camera to wake up often, increasing power consumption. You may also consider adjusting the camera’s angle to avoid high-traffic areas, or lower the sensitivity settings to reduce the frequency of triggers.
If battery has drained out, please note it may take time to fully charge it. t0 aoind draining battery imit Live Viewing: Regularly viewing live feeds or playback can drain the battery. It’s advisable to access these features only when necessary.
Alternative Solar Panel Setup: If your device have a fixed solar panel that cannot be moved to a better sunlit area due to installation constraints, consider connecting an additional solar panel to improve charging efficiency. Good luck!
1- Ensure that the solar panel is positioned to receive direct sunlight and is not obstructed by eaves, tree leaves, or other shadows.
2- Reduce Camera Activations: Frequent motion triggers can cause the camera to wake up often, increasing power consumption.
3- Consider adjusting the camera’s angle to avoid high-traffic areas, or lower the sensitivity settings to reduce the frequency of triggers.
4- Limit Live Viewing: Regularly viewing live feeds or playback can also drain the battery. It’s advisable to access these features only when necessary.
5- Alternative Solar Panel Setup: If your device have a fixed solar panel that cannot be moved to a better sunlit area due to installation constraints, consider connecting an additional solar panel to improve charging efficiency.
6- If none of the above help, please contact AOSU Support.
Relocate the solar panel to get as much direct sun light as possible.
Amazing news, trying to figure out how to DM for the prize but I’m just not seeing it. @aosu_Captain
Hi.I have send the message to you privately.
