My L5P camera suddenly started giving Audio warnings “Warning. You have entered a high definition surveillance area”. To my knowledge I have not changed settings through the app. How can I shut this feature off or disable it when we are home and activate it when we want it back on?
Hi
I have disabled the audio warning. Go to AOSU app and camera settings. The option is in AI surveillance section. Where there is a intrusion section. Look in Sound Alarm and turn off
It has been 10 days since the Firmware update that caused this unwanted change, what is the status update on a fix? The information on how to turn these messages off is not accurate to the App version which is 5.3.11 the latest according to Google Play. Can we please get some info here?
Hurray for you sir. That setting is in the Parking Guard section as well, surprisingly these sections were not used or selected by me yet one of them was activated every time I turned on Motion Detection for a camera. Why must a User of the system be the one to give clear instructions. I have yet to test and confirm this, but I have no doubt you found the magic setting.
Hi,
We’re truly sorry to hear that you’re experiencing this issue!
To get this resolved for you as quickly as possible, please reach out to our dedicated support team directly through the app. Our live agents will be able to assist you one-on-one and investigate the details.
How to reach us:
Open the aosu App ➔ Tap Support (bottom right) ➔ Select Online Support to start a chat.
Thank you for your patience and support!
