[Round 35 | aosu Security Quiz] How Can I Reduce Unnecessary Alarm Sounds?🚹
:police_car_light: :house_with_garden: Round 35 – Practical Scenario: “How Can I Reduce Unnecessary Alarm Sounds?
:bullseye: :red_question_mark: Q: How can you turn off the audiovisual alarm on your cameras?
Picture this:
You installed several outdoor cameras around your home to keep things safe and secure. :house_with_garden:
Everything was set up carefully through the app, and the system is working well. :+1:
One evening, someone from your family walks through the yard. :person_walking:
The camera detects motion and briefly triggers the alarm sound to alert you. :police_car_light:
You start thinking:
:thinking: What settings can you adjust in the app to reduce unnecessary alarm triggers while keeping your home protected?
That way, the system can still protect your home without unnecessary alarm sounds, especially during quiet hours in the neighborhood. :crescent_moon:
:magnifying_glass_tilted_right: You can find the answer in the aosu Community.
:backhand_index_pointing_right: Search “deactivate the alarm sound ” in the top-right search bar. :laptop:
:wrapped_gift: Prizes Up for Grabs
  • :balloon: Lucky Winner — 14-day Monthly Cloud Storage Service ×1 :cloud:
  • :trophy: Monthly Grand Prize — aosu Indoor Camera ×1 :video_camera: (join 3+ quiz rounds to qualify)
:white_check_mark: How to Participate
  1. Go to the aosu Community and search for the article title.
  2. Read the article and leave your answer in the comments under this post.
    All correct answers will enter this week’s lucky draw!
:alarm_clock: Quiz Period: Mar 11 – Mar 17
:loudspeaker: Winners Announced: Next Wednesday in the comments — stay tuned! :eyes:
:light_bulb: Think you know the answerCome to win prizes!
Pur rĂ©duire les alertes inutiles, je vais dans « DETECTION » et je choisis les option « dĂ©tection Intelligente » et les sous rubriques qui m’intĂ©ressent. Avec l’abonnement protect+ c’est l’IA qui m’alerte en cas d’animal sauvage Ă  proximitĂ© ou si quelqu’un porte une arme.
Pour Ă©viter les “fausses” alarmes :police_car_light: il suffit de rĂ©duire la sensibilitĂ© dans l’onglet DÉTECTION. Le mode “intelligent” permet de sĂ©lectionner ce pourquoi on souhaite recevoir une alerte.
De plus, cela permet d’économiser la batterie sur les camĂ©ras solaires.
1. Turn Off Alarm in All Security Modes
  • Aosu App → Home > Security Mode > Away Mode / Home Mode
  • Ensure Siren and Flashing Light are OFF for each camera under both modes.
:counterclockwise_arrows_button: Do this for Disarmed Mode as well — sometimes it has separate settings.
2. Turn Off Per-Camera Alarm Settings
Some camera models retain local alarm behavior even when system modes are off.
  • Aosu App → Devices > [Select Camera] > Settings > Alarm Settings
  • Turn OFF:
    • Siren
    • Flashing Light
    • Warning Sound
    • Active Deterrence (if available)
Repeat this for each of the 4 cameras.
3. Disable Automation Triggers
There may be automation rules triggering the alarm regardless of your mode settings.
  • Aosu App → More > Automation
  • Look for any rules like:
    • “If motion is detected → trigger audiovisual alarm”
  • Delete or disable these automation rules.
:bell: A bug in automation may cause rules to apply even when modes say “off”.
4. Update Firmware
Outdated firmware might ignore or override your settings.
  • Aosu App → Device > Camera Settings > Device Info > Firmware Version
  • Tap Check for Updates for:
    • Each camera
    • The aosubase
5. Power Cycle the System
Sometimes the alarm settings only take effect after a full reboot.
  • Unplug the aosubase, wait 30 seconds, then plug it back in.
  • Turn off and restart each camera (via the app or manual power if solar/battery).
If none of the above can solve the problem, please contact our online support on the aosu app.
You can turn off the audio alarm in the settings. In the Aosu app, check the camera’s setting, select auto alarms, add alarm period, make a custom alarm and lightly click the alarm sound to cancel it. That way the camera will still trigger the light alarm, but won’t turn on the audio siren.
1. Turn Off Alarm in All Security Modes (Already Done)
Turn OFF: Siren, Flashing Light, Warning Sound, Active Deterrence (if available)
Repeat this for each of the cameras.
4. Update Firmware
Tap Check for Updates for: Each camera and The Aosubase
Unplug the Aosubase, wait 30 seconds, then plug it back in.
If none of the above can solve the problem, please contact Aosu online support on the Aosu app.
Turn Off Alarm in All Security Modes. Aosu App → Home > Security Mode > Away Mode / Home Mode. Make sure Siren and Flashing Light are OFF for each camera under both modes.
Another way is to turn Off Per-Camera Alarm Settings. Some camera models retain local alarm behaviour even when system modes are off. You will need to open Aosu App → Devices > [Select Camera] > Settings > Alarm Settings and Siren, Flashing Light, Warning Sound, Active Deterrence (if available).
Ensure the Aosu app and cameras/Aosubses’s firmware are updated.
The most common solution is to turn Off Alarm in All Security Modes. To do this open Aosu App, then select home, then Security mode, then Away Mode / Home Mode. Or, Turn Off Per-Camera Alarm Settings. Some camera models retain local alarm behaviour even when system modes are off. Open Aosu App → Devices > [Select Camera] > Settings > Alarm Settings and Siren, Flashing Light, Warning Sound, Active Deterrence (if available).
Aosu App → Home > Security Mode > Away Mode / Home Mode. Ensure Siren and Flashing Light are OFF for each camera under both modes. This will turn Off Alarm in All Security Modes. Alternatively, Turn Off Per-Camera Alarm Settings. Some camera models retain local alarm behavior even when system modes are off. Go to Aosu App → Devices > [Select Camera] > Settings > Alarm Settings and Siren, Flashing Light, Warning Sound, Active Deterrence (if available). It is advisable also to update outdated firm ware . Aosu App → Device > Camera Settings > Device Info > Firmware Version. Tap Check for Updates for: Each camera and The aosubase.
‱ Turn Off Alarm in All Security Modes: Aosu App → Home > Security Mode > Away Mode / Home Mode. Ensure Siren and Flashing Light are OFF for each camera under both modes.
‱ Turn Off Per-Camera Alarm Settings. Some camera models retain local alarm behavior even when system modes are off. Go to Aosu App → Devices > [Select Camera] > Settings > Alarm Settings and Siren, Flashing Light, Warning Sound, Active Deterrence (if available).
‱ There may be automation rules triggering the alarm regardless of your mode settings. Go to Aosu App → More > Automation and Look for any rules like: “If motion is detected → trigger audiovisual alarm”. Delete or disable these automation rules.
‱ Outdated firmware might ignore or override your settings. Go to Aosu App → Device > Camera Settings > Device Info > Firmware Version. Tap Check for Updates for: Each camera and The aosubase.
  • Turn OFF:
    • Siren
    • Flashing Light
    • Warning Sound
4. Update Firmware
    • Each camera
    • The aosubase
Audio alarm can be switched off in the App settings. Go to camera’s setting, select auto alarms, add alarm period, make a custom alarm and lightly click the alarm sound to cancel it. That way the camera will still trigger the light alarm, but won’t turn on the audio siren
  • Turn Off Alarm in All Security Modes
Ensure Siren and Flashing Light are OFF for each camera under both modes. Do this for Disarmed Mode as well — sometimes it has separate settings.
Turn OFF: Siren, Flashing Light, Warning Sound, Active Deterrence (if available).Repeat this for each of the cameras.
Look for any rules like: “If motion is detected → trigger audiovisual alarm”. Delete or disable these automation rules. A bug in automation may cause rules to apply even when modes say “off”.
4. Update Firmware
Tap Check for Updates for: Each camera and The Aosubase.
Sometimes the alarm settings only take effect after a full reboot. Unplug the Aosubase, wait 30 seconds, then plug it back in. Turn off and restart each camera (via the app or manual power if solar/battery). If none of the above can solve the problem, please contact Aosu online support on the Aosu app.
Two most common solution
1- Open AOSU App, then select home, then Security mode, then Away Mode / Home Mode. Or, Turn Off Per-Camera Alarm Settings. This way you can turn Off Alarm in All Security Modes.
2- Some AOSU camera models retain local alarm behaviour even when system modes are off. This can potentially cause some problems with turning off audio alarms. To address this issue, open AOSU App → Devices > [Select Camera] > Settings > Alarm Settings and Siren, Flashing Light, Warning Sound, Active Deterrence (if available).
To Turn Off Alarm in All Security Modes.:
To turn Off Per-Camera Alarm Settings:
Check that the Aosu app and cameras/Aosubses’s firmware are updated.
Below are some options available to reduce or avoid unnecessary alarm sound when using aosu security camera:
  1. Turn off alarm on all security mode.
    Steps to follow:
  2. Turn off per camera alert settings
    Steps to follow:
    Turn OFF:
    Siren
    Flashing Light
    Warning Sound
    Repeat this for each of all the cameras.
  3. Disable automation triggers
Follow these steps to correct it:
  1. Update Firmware
    Ensure your cameras and undefined are updated to the latest firmware.
Steps to follow:
Each camera and the undefined.
  1. Power Cycle the System
:smiling_face_with_three_hearts:
:trophy: Aosu Security Quiz Event – Winner Announcement
:tada: Winners Round 35 Announced!
The lucky winner of Round 35 is: @sonata
Prize: 14-day monthly cloud storage service ×1 :balloon:
:confetti_ball:Congratulations to @sonata !!
:envelope_with_arrow: Please contact our team via private message to @aosu_Captain or the official account to claim your prize!
:mobile_phone: You can also share on WhatsApp
:raising_hands:The 36th round of our security knowledge quiz with prizes has begunCome answer the questions and win prizes
@sonata congratulations :clap::tada:
