No recording over night?
My cameras don’t seem to record over night. The one works till about 11pm the. Not again till 7am. I have reset and checked all settings and nothing changes. Please help. Night is when I want it to record most
Yes, I understand your point of view; this can indeed be inconvenient. :folded_hands:Perhaps you could try the following adjustments first:
1. Check Motion Detection / Event Settings
If your cameras rely on motion detection:
Ensure motion detection sensitivity is high enough for nighttime.
Some cameras turn off motion detection at night to reduce false alarms.
2. Check Night Vision / Infrared Settings
Some cameras stop recording if night vision fails or if the infrared sensor isn’t activated.
Make sure night vision is enabled in settings.
3. Firmware / App Updates
Outdated firmware can cause recording gaps.
Update camera firmware and your app to the latest version.
If the above solutions don’t resolve the issue, you can find online support on the Aosu app; they will provide one-on-one assistance. Hope this helps, and thank you for your support.
