QR Code synch issues
My camera will not read the QR code on my phone when syncing to the aosuCortex?
Hey There,
so sorry to hear this, please try
  1. Clean the Camera Lens
  • Sometimes a simple wipe with a soft cloth can help the camera focus properly.
  1. Adjust Your Screen Brightness
  • Make sure your phone’s brightness is turned all the way up. A dim screen can make the QR code hard to scan.
  1. Hold Steady & Keep Distance
  • Hold your phone about 6–8 inches away from the camera.
  • Move slowly in or out until the camera beeps or blinks, indicating a successful scan.
  1. Avoid Screen Glare
  • Try tilting your phone slightly or shielding it from overhead lighting that might reflect off the screen.
  1. Increase QR Code Size
  • If you’re using a smaller phone or have a protective case, you can try zooming in on the QR code in the app to make it larger.
  1. Check Your App and Firmware
  • Ensure you have the latest version of the AOSU app and your aosuBase is up to date.
Also just to clarify this camera came with the aosuBase right ?
all the best,
s.s
