- Kindly follow the steps below to isolate or fix the issue.
- Ensure that the HomeBase is not powered off.
- Unplug (1-2 minutes) and re-plug the HomeBase.Check if the router can access the internet .
- Try also to restart the router.Kindly check if the CameraHomeBase has an available firmware update.
- Go to CameraHomeBase settings Firmware updates, then Update.
- Try to reconfigure the HomeBase and the camerasIf the issue is not resolved, kindly provide online support on aosu app with the HomeBase’s serial number
