Viewing local data on PC
How do i go about viewing local events/data on a PC?
I want to bulk download events/data with out going through the phone. Files from SD card dont seen to be in a usable format.
The Aosu app is only compatible with Android or iOS platforms. It is not compatible with Windows or any computer platforms yet.
In what format are the video files from your SD card?
but how to open it? I saved them on cd card. saved on google-drive. then try to open on my iPhone and I can’t.
Dear User,
Currently, the official Aosu app is only available on iOS and Android mobile devices.
However, there is a workaround: you can download an emulator on your PC and then install the Aosu app. Please note that the app was not designed for PCs or TVs, so its functionality may not be perfect. For the best experience, I recommend using BlueStacks or downloading the XAPK file from a trusted source.
Additionally, when downloading videos from your SD card, they are saved as MP4 files, which are compatible with most devices and websites. A simple solution is to download the videos onto your phone and then send them via WhatsApp to your laptop, if necessary.
Hope this helps,
S.S
