Will the AOSU solar outdoor cameras work without the HomeBase?
Good day,
Good question , AOSU actually makes two types of camera systems:
- Standalone Wi-Fi cameras (like the ones I have), which connect directly to your Wi-Fi and work without a HomeBase at all.
- HomeBase kits, where the cameras are specifically paired with a HomeBase. In that case, the cameras wonât work independently , they rely on the HomeBase for connection, storage, and sometimes AI features. Even if you have strong Wi-Fi, they canât connect without the HomeBase because theyâre not designed to work on their own.
So if your kit came with a HomeBase, it has to stay connected for the system to function. But if it didnât, youâre likely using the standalone version, which works just fine over Wi-Fi.
Let me know which model youâre using if youâre not sure, happy to help.
All the best,
S.S
