HomeBase Wifi Setup
I purchased the kit with two outdoor solar cameras and a HomeBase. I set everything up with the ethernet connection between the HomeBase and my Starlink Mini. Can the HomeBase operate without the ethernet connection, only using wifi from the Starlink Mini?
Good day,
Yes, the AOSU HomeBase can run on Wi-Fi without the Ethernet connection, even with your Starlink Mini. You’ll just need to complete the initial setup using Ethernet first. Once that’s done and everything’s updated through the AOSU app, you can disconnect the Ethernet cable and switch the HomeBase to Wi-Fi.
It supports both 2.4 GHz and 5 GHz, so your Starlink Mini’s wireless signal should work fine, just make sure the HomeBase is placed somewhere with a strong Wi-Fi connection.
Let me know if you run into any issues setting it up.
All the best,
S.S
I have the AOSU app for Android 4.2.55 and under settings there is no network or wifi settings!
Hi, I have a similar question. In my Homebase settings, I don’t see any Wi-Fi option available.
AOSU wrote me and my system (1 home base H1L and 4 cameras) can not be used without Ethernet, no local WiFi connectivity. That’s fine with me because I have an extra Ethernet port to use.
Please use an Ethernet cable to connect the base station to the router, and the network port indicator light is on. Homebase needs to be connected to an Ethernet cable.
