iPhone settings for Aosu Doorbell camera
you need to enable microphone permissions in your iPhone settings and the Aosu app to make the mic work. Ensure your iPhone is not muted, allow the app to access the microphone, and increase the volume within the app’s live view settings for two-way audio to function.
Here is how to fix it:
iOS Permissions: Go to iPhone Settings > Privacy & Security > Microphone, and ensure the toggle for the Aosu app is turned on.
App Settings: Open the Aosu app, go to Settings > Video Audio, and ensure “Record sound” is turned on.
Two-Way Talk: In the live view, ensure the microphone icon is not muted, and check the “Two-way talk” settings to increase the volume.
Troubleshooting: If it still does not work,
try turning off Bluetooth to ensure it is not trying to use a disconnected headset, or restart the app.
This video demonstrates how to adjust the audio settings in the Aosu app:
Ensure the microphone isn’t muted in the app during live video to guarantee two-way talk functionality, as seen in the video above.
Android settings for Aosu Mic
You need to enable microphone permissions in your Android settings and within the Aosu app to get the two-way audio working. Specifically, navigate to Settings > Apps > Aosu > Permissions > Microphone and ensure it is set to “Allow”. Also, verify the in-app audio settings are active and the volume is up.
Actionable Steps to Fix Aosu Microphone:
Check Android Permissions: Go to your phone’s Settings > Apps (or Apps & Notifications) > Aosu App > Permissions > Microphone. Ensure it is set to Allow or “Allow while using the app”.
Enable In-App Audio: Open the Aosu app, go to the live view, and check that the microphone icon is not muted.
Adjust Volume Settings: In the Aosu app, go to Settings > Video Audio and ensure “Record sound” is enabled. Furthermore, go to Two-way talk speaker to increase the volume.
Restart/Reinstall: If permissions are correct but the mic still doesn’t work, restart your Android phone or uninstall/reinstall the Aosu app to re-trigger the permission request.
If you are using Bluetooth headphones, speak directly into your phone instead of relying on th
e headset microphone.
