P1 SE not showing video
P1 SE solar cam isn’t showing the video. Everything else looks normal. I can see on the app that the battery is full, wi-fi good. The blue light on the front is on. I can control that going on and off. I’ve tried restarting multiple times with no results. I took down the camera and tried restarting manually no results. when I try to see the live feed app shows that is setting the channel then detecting the Wi-Fi then loading the live feed however, that’s where it ends. The error says video play failed, please try again and then there’s a refresh button. I hit the refresh button and the same thing happens. Tried hitting the reset button on the bottom of the camera and that didn’t change anything. not sure what to do next.
Pk
