Last night we were walking near one of the cameras in the front of the house. Lights didn’t run on as we walked within 10 feet of it. Is there a setting that needs to be changed
If your Aosu camera didn’t turn on the lights when you walked near it, it’s likely due to motion detection or night vision settings. Here’s how to fix it:
What to do:
- Increase Motion Detection Range
Open the Aosu app
Go to the camera settings
Look for Motion Detection Distance and set it to Far - Turn on Color Night Vision
In the same settings menu, go to Night Vision Mode
Select the middle option: Color Night Vision
This turns on the spotlight when motion is detected at night - Other Tips:
Make sure the camera is clean and not blocked by anything
Ensure the Motion Detection toggle is on
Check the Activity Zone (if enabled), the area you walked in might not be within the detection zone
Make sure your firmware is up to date in the app
After adjusting these, your camera should detect motion better and turn on the lights when it senses someone nearby.
All the best,
S.S
