Before each network connection, please confirm that the camera has been reset (long-press the SYNC button at the bottom of the camera until a “beep” sounds and the green indicator flashes)
- Check whether the SSID is capitalized correctly in the input Wi-Fi information
- Check whether the password is correct in the entered Wi-Fi information
Confirm that the router can connect to the network normally (when the mobile phone is connected to the router, it can be used in the network normally)
Check the distance between the camera and the router: if the distance is too far or there are obstacles (such as walls, etc.), the overall Wi-Fi signal may be weak.
Check your router’s Wi-Fi encryption type, if it is WEP mode, it is recommended to change it to WPA or WPA2
Confirm that the router does not have a MAC address whitelist set.
