[Round 27 | aosu Security Quiz] Offline Again?
:bellhop_bell: Round 27 , “Offline Again?”
:hushed_face: Imagine this:
You’re at work and can’t get home, but your aosu camera keeps going offline. Live view won’t load, and alerts stop coming through—leaving you wondering what’s happening at home. What would you do to solve it? :white_check_mark:
:bullseye: Q: Why does the network connection always fail?
:magnifying_glass_tilted_left: You can find the answer in the aosu Community.
:backhand_index_pointing_right: Search “Why does the network connection always fail?” in the top-right search bar. :desktop_computer:
:wrapped_gift: Prizes Up for Grabs
  • :balloon: Lucky Winner— 14-day Monthly Cloud Storage Service ×1 :cloud:
  • :trophy: Monthly Grand Prizeaosu Indoor Camera ×1 :video_camera: (join 3+ quiz rounds to qualify)
:white_check_mark: How to Participate
  1. Go to the aosu Community and search for the article title using the search bar in the top right corner.
  2. Read the article and leave your answer in the comments section of this post.
  3. All correct answers will be entered into this week’s prize draw!
:three_o_clock: Quiz Period : Dec 24 – Dec 30
:loudspeaker: Winners Announced: Next Wednesday in the comments — stay tuned! :eyes:
:light_bulb: Think you know the answer?
Come and answer the questions! :glowing_star: :glowing_star:
Before attempting to connect to the network, make sure the camera has been reset by long‑pressing the SYNC button at the bottom of the device until you hear a beep and the green indicator begins flashing.
  • Verify that the SSID has been entered with the correct capitalization.
  • Ensure the Wi‑Fi password has been entered accurately.
  • Confirm that the router is functioning normally by checking whether your mobile phone can connect to it and access the internet.
  • Check the distance between the camera and the router. If they are too far apart or separated by obstacles (such as walls), the Wi‑Fi signal may be weak.
  • Review your router’s Wi‑Fi encryption settings. If it is set to WEP, switch to WPA or WPA2 for better compatibility.
  • Make sure the router does not have a MAC address whitelist enabled.
Before each network connection, please confirm that the camera has been reset (long-press the SYNC button at the bottom of the camera until a “beep” sounds and the green indicator flashes)
  • Check whether the SSID is capitalized correctly in the input Wi-Fi information
  • Check whether the password is correct in the entered Wi-Fi information
Confirm that the router can connect to the network normally (when the mobile phone is connected to the router, it can be used in the network normally)
  • Check the distance between the camera and the router: if the distance is too far or there are obstacles (such as walls, etc.), the overall Wi-Fi signal may be weak.
  • Check your router’s Wi-Fi encryption type, if it is WEP mode, it is recommended to change it to WPA or WPA2
Confirm that the router does not have a MAC address whitelist set.
Always test your camera before mounting as well
If you’re away from home, there isn’t much you can do if your cameras go offline beyond ensuring your phone has a working network connection and power cycling it. Sometimes I’ve had apps not work/perform poorly until it was given a reset.
When you get home, you can perform better checks:
There are other possible issues like the camera’s battery being completely discharged that would cause it to go offline.
To troubleshoot your camera’s connection, follow these steps:
Reset the Device: Hold the SYNC button until you hear a beep and see the green light flash.
Verify Credentials: Double-check that your Wi-Fi name (SSID) and password are correct, including capitalization.
Test Connection: Ensure your router is online and placed close to the camera, away from thick walls or interference.
Update Settings: Set your router’s encryption to WPA or WPA2 (avoid WEP) and disable any MAC address whitelists.
:trophy: Aosu Security Quiz Event – Winner Announcement
:tada: Winners Round 27 Announced!
:one: The lucky winner is: @makaveli3004
Prize: 14-day monthly cloud storage service ×1 :balloon:
:two: The winner of December’s monthly @helenmainen
Special Monthly Prize: Aosu Indoor Camera×1 :trophy:
:confetti_ball:Congratulations to the above winners!!!
:envelope_with_arrow: Please contact our team via email [community@aosulife.com] to claim your prize!
:mobile_phone: You can also share on WhatsApp
:wrapped_gift: :rocket: Round 28 Begins Now!
Test your knowledge, join the fun, and stand a chance to win exciting rewards.
Come and get involved now!
