Wireless battery operated camera system
aosuCortex is plugged into power and connected to the router. It continues to blink green. Has not turned blue after several minutes. What to try next?
Once I tood the plastic film off the camera, everything started working.
Hello, will.
You can follow the tutorial step by step, and there will be instructions for specific operations. I am glad to see that the problem has been solved.
Welcome to join the community. It seems that you have just installed a new aosu camera. I hope you will like this product and I am looking forward to you sharing your experience with the product. :blush:
