Pourquoi ma camera a recharge solaire ne se charge plus
Bonjour
Malgré une vérification de connection, d’orientation , de wifi ok et de nettoyage du solaire, la caméra ne se charge plus au soleil pour quelle raison ?
Which camera model do you own? Aosu sells ones where the solar panel is a separate item that is attached via USB-C as well as cameras that have it directly integrated in the housing.
If you own the former, there are a few things you can check to rule out failure points. Unplug the solar panel, grab a power bank and plug that in. If your camera starts charging, then you know your USB port and camera’s battery likely aren’t the issue. It’s possible the solar panel or its wiring is damaged. You can try repairing that or buying a replacement.
Also, it’s late November. If you live in the Northern hemisphere, it’s colder and there’s less light. That does impact charging performance, but it shouldn’t be completely dead.
